time2roll
Jan 11, 2016Nomad
Gerald55 wrote:What happens when you unplug?Ungrounded electrical equipment leaves open the possibility that YOU become the ground.
As I mentioned above, the unit is already grounded, via the AC ground wire.
The idea for installed equipment is to have a separate permanent ground connection independent of all power connections.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
