jharrell
Dec 09, 2018Explorer
My Magnum inverter has a separate ground lug that the manual says specifically to tie to chassis. The manual also specifically says not to use the chassis as DC negative, in their words:
"Do not attempt to use the chassis in place of the battery negative connection for grounding.
The inverter requires a reliable return path directly to the battery."
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
