BFL13
Dec 09, 2018Explorer II
pauldub wrote:
OP here. I'll have half my battery bank on the curb side of the motorhome and the other half on the street side. To wire the batteries in a balanced fashion will take extra wire length. This is most of my motivation to ground the inverter DC return directly to the frame. I'll use a tin plated lug which is galvanically compatible with the steel frame. I can also use a chrome plated bolt so that the bolt will be galvanically compatible with the steel and tin.
I have a diagram a member from back then posted in 2011, but the dropbox has expired. He had a similar situation with two battery banks separated like that in his MH. (two sets of 6v pairs and a 2000w inverter/charger with an 80 amp charger)
For the neg side from each set he ran a wire to frame ground. On the positive sides wires to a 1,2, both switch, from that switch to the inverter pos intake. Inverter neg intake from frame ground.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
