jharrell
Dec 10, 2018Explorer
BFL13 wrote:
I think you are right from reading the manual where they use "chassis". It is true they all use the frame but separately, sort of.
See page 12 diagram. There is a "system" ground to the frame AND the neg from the battery to the inverter neg intake. Also there is an inverter chassis ground (equipment ground) to the frame.
Also something in there about the accessories like the monitor ending up as the neg path if you are not careful.
http://www.magnum-dimensions.com/sites/default/files/MagDocs/64-0089%20A%20Owner%20Manual%2C%20MSH3012RV%20Series.pdf
Diagram on page 26 makes it very clear:
