MrWizard
May 16, 2015Moderator
you have fifth wheel ?
it has got to have more than two circuit breakers, sound like that breaker is the manual transfer switch
to switch between shore power and generator
that should be OFF, you should be hooked up the same as shore power
using inverter same as SP, converter will still be on unless you turn off the regular circuit breaker or install a switch, you might have another GFI, someplace
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
