time2roll
May 17, 2015Nomad
lxapilot wrote:Pull the cover off so you see all the 120v wires.
I have the wfco wf-8900 which may make things more difficult. I didn't realize some rigs have separate converters.
One of the breakers will have two wires that are attached. One is the branch circuit and the other is the converter. You need to cut this wire and put the converter on a separate breaker than can be off. 20 minute job max.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
