My rv has an add on 2000 watt inverter installed by previous owner. An extra 30 amp outlet was installed in power cord compartment. I assume in order to run any ac while boondocking I would plug my sh...
Ths will work fine as long as you make sure that your converter is turned off. If the converter is on it will try to charge your batteries with the battery power that your inverter using from your batteries.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
