My rv has an add on 2000 watt inverter installed by previous owner. An extra 30 amp outlet was installed in power cord compartment. I assume in order to run any ac while boondocking I would plug my sh...
The general purpose breaker seems to be the one that works but only if main is on also which defeats the purpose. Then tried disconnecting negative from main converter breaker to no avail. time2roll when you advise to move power black wire to new breaker you mean main incoming power? Can I use an inline breaker for this? Sorry to be so misinformed but am learning and seriously trying to figure this out so thank you all for your patience
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
