JR51's avatar
JR51
Inverter info
My rv has an add on 2000 watt inverter installed by previous owner. An extra 30 amp outlet was installed in power cord compartment. I assume in order to run any ac while boondocking I would plug my shore power cord into this outlet and turn on the inverter. Are there any precautions to this method or is it a pretty straight forward process?
  • jdc1's avatar
    jdc1
    Explorer II
    Shouldn't the converter be turned off while doing that?
  • By ac do you mean 120v current or air conditioning...because you won't be running air for very long. Yes, just plug in to that socket, but don't have any high draw devices on when you do that, and make sure your converter and hot water are off.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
