pianotuna
Mar 12, 2015Nomad III
Hi dons2346,
Actually an absorption fridge has a duty cycle of 2:3 (on for forty minutes per hour). Mine draws 325 watts so the daily resources needed are 5.2 kwh's. A residential fridge such as the Samsung referenced draws less than 1.5 kwh per day.
dons2346 wrote:naturist wrote:
you will have to install a massive battery bank to feed it, and you will have to run a generator a lot every day.
The above colored statements are not really true. You can use a small 600 watt inverter to power the fridge. You will find that most residential refers will consume about the same amount of watts that a absorption refer will.
