larry_cad
Mar 19, 2020Explorer II
First question - is any of this a concern?
YES
Second question - why is it still registering "open ground"?
Taken at face value, assume it is because there is still an open ground, from the outlet to the inverter chassis
Third question - if I do need to ground it, how do I do so?
Assuming the outlet is fed directly from the inverter with appropriate wiring type such as romex, it is likely there is a ground wire in the romex. Insure the ground wire is attached at both ends, the outlet at one end and the inverter chassis at the other end.
YES
