- Boon_DockerExplorer IIIJust did a test on my inverter mic and at full power it draws 16 amps. At 50% power it draws 8 amps. Tested with a Kill A WATT meter.
- GdetrailerExplorer IIIInteresting question..
I am looking at a new MW for our TT and the inverter MWs sure are tempting, the one we looked at was rated 1250W output but only required 1400W input.. The reason we are are considering an inverter MW is getting more than 1100W output but using the same power as a 1100W non inverter MW.
I suspect though if you set an inverter MW for 50% it will more than likely PWM modulate the on vs off time like regular non inverter MWs averaging over all lower wattage but with high wattage spikes when on.
But would be interesting to see if anyone that has an Inverter MW sees anything different than my guess..
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
