time2roll
Mar 19, 2014Nomad
The converter powers the 12v items when plugged in or generator running and battery is disconnected. While driving you need to turn on the house battery switch for 12v power use in the house. The power will be replenished by the alternator.
If you have an inverter it would be used to power 120vac items without plugged in or generator.
Generally the house battery switch should be ON while the RV is in use.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
