RoyB
Mar 20, 2014Explorer II
This is a typical 30AMp wiring configuration setup for trailers from GOOGLE Search.
Sounds like you are mixing up an INVERTER with the CONVERTER. In the RV world they are two different animals.
This layout is really for trailers but the motorhomes follow the same basic ideas.
The POWER INVERTER statement above should say 12VDC to 120VAC.
Hope this helps...
Roy Ken
Hope this helps...
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
