MNtundraRet
Mar 23, 2014Navigator
Mihand35 wrote:
Yes I know where the inverter is, I know what it powers. The TV and DVD player in the back. I have two house batteries and no matter what position my switches are in, they don't come on or power anything.When I connect to shore power or run the gen, everything works, including the inverter. That is what I expect to work, but the two house batteries should at least power the inverter right? I guess I have some wire tracing to do.
So far you giving confusing answers each time.
Now you are saying that when not plugged in you have no 12v circuits working (12v lights, etc.). House-batteries disconnected from the circuit.
This can mean only one thing. The battery-disconnect solenoid has failed. The separate inverter could work if wired separately to the house-battery bank. In your case it looks like it was wired to need the House-batteries connected.
Without a working solenoid you are out of luck. See an experienced RV repairman.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
