Mihand35
Mar 23, 2014Explorer
MrWizard wrote:
there should be battery disconnect switches,
could be a rocker switch, has too be held down or up for just a moment
to cause a "relay" aka battery disconnect to be operated
sometimes its a single push button membrane switch with a little led light next to it
one push ON, next push OFF
Yes I was given a walk-thru, but he showed me the inverter worked, I didn't realize all those things ran off the batteries. So I didn't check with shore power off.
I have those two switches one of them kills the power to the coach (the ignition up front) and the other kills the power to the house part. If i turn off the house switch it turns the generator off. The only way I can everything with both switches off is to run on shore power.
Does this sound like what is supposed to happen with the switches??
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
