MrWizard
Mar 23, 2014Moderator
NO.. its not
but it sounds like the house battery disconnect is working (12v to the generator starter is removed when you operate the switch)
somehow the batteries are NOT feeding any power to the DC distribution center
(the box with the 12v fuses)
could be a bad master fuse, could be a disconnected wire
start at the HOUSE fuse panel and check fuses and trace wiring, back towards the batteries
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
