time2roll
Sep 26, 2014Nomad
sjturbo,
Power only goes one way in a 120v circuit. You cannot use a wire to feed the converter and use the same wire to back feed the inverter.
You need to pull two wires to the front if you want this wired correctly. Or you can place the inverter in behind the breaker panel and use the existing 12v main connection.
