sjturbo
Sep 26, 2014Explorer
pianotuna wrote:
Hi,
If the genny back feeds the inverter you may damage both. I don't like transfer switches.
It would be simpler by far to feed the plugs direct from the inverter and always have it on. The OEM converter would power the inverter whenever the 30 amp plug is being fed.
Thanks for the input. I assume that you are referring to back feeds in case of a transfer switch failure? I really do not do separate 30' and 15' runs of 12/2.
The inverter will basically be used when boondocking only for the TV,DVD or Sat. so leaving it on all the time seems to be a bad waste of good battery energy.
