- Bigfoot2005Explorer
time2roll wrote:
Bigfoot2005 wrote:
Do you have the inverter? The manual I read says it comes with ring terminals so I assume it has 3/8" stud to connect the ring.
Anyone know the largest size wire a Go Power 1500 watt inverter can take?
Or exactly what model do you have?
No, I don't have the unit yet but will get the Go Power GP-ISW1500 Bigfoot2005 wrote:
Or exactly what model do you have?- vermilyeExplorer II
Bigfoot2005 wrote:
phemens wrote:
Bigfoot2005 wrote:
ktmrfs wrote:
Bigfoot2005 wrote:
What type of power cables can be used for battery connections to 1500 watt inverter?
CCA or OFC
I use welding cable. I attach my own ends with a hydraulic crimper but most welding stores will attach lugs for you. Welding cable is much easier to run, nice thick insulation very fine stranded wire so it is easy to route. you can get colors but I just get black and then attach red shrink wrap on the ends. Compare 4/0 welding cable to std variety 4/0 battery cable. you'll immediately see the advantage to welding cable. For my 1000W inverter I use 4/0 welding cable.
what thickness should be used for about 10-15 feet run for a 1500 watt inverter? I know it should be as close as possible to batteries but just for convenience, hoping to put further away with a thicker wire if possible.
I keep my 3000 watt inverter about 2 feet from battery bank (not wet cell), and I use 4/0 welding cable as mentioned. That will be tough to run 15 feet as you want, I'd look at a way to get it closer and the if needed run 120 AC from there (much easier). Anything less than 4/0 and I don't think you'll like the voltage drop, unless you're keeping the draw to something other than microwave/coffee maker/etc.
My GoPower GP-HS1500 is designed to use lugs (3/8" Ring) for the connections. 2/0 crimped lugs needed to be shaved a bit on the sides to fit into the space for the bolts. Cables from GeunineDealZ... - RollandBExplorerAnother 4/0 welding cable, lots of tiny strands of cooler wires. Used a hydraulic crimper for the lugs.
Im working on the install of a 3000W Magnum Hybrid i should finish today. Just need to connect it to the battery bank, do the function testing and set the charger specs. - Bigfoot2005Explorer
phemens wrote:
Bigfoot2005 wrote:
ktmrfs wrote:
CCA or OFC
Anyone know the largest size wire a Go Power 1500 watt inverter can take? - phemensExplorer
Bigfoot2005 wrote:
ktmrfs wrote:
CCA or OFC
I keep my 3000 watt inverter about 2 feet from battery bank (not wet cell), and I use 4/0 welding cable as mentioned. That will be tough to run 15 feet as you want, I'd look at a way to get it closer and the if needed run 120 AC from there (much easier). Anything less than 4/0 and I don't think you'll like the voltage drop, unless you're keeping the draw to something other than microwave/coffee maker/etc. - wa8yxmExplorer III
ktmrfs wrote:
CCA or OFC
Same here.. And NO I would not use copper coated aluminum. I want Solid (or rather stranded) copper wires.. CCA might be ok for RF but never for DC. - Bigfoot2005Explorer
ktmrfs wrote:
CCA or OFC
what thickness should be used for about 10-15 feet run for a 1500 watt inverter? I know it should be as close as possible to batteries but just for convenience, hoping to put further away with a thicker wire if possible. - MEXICOWANDERERExplorerI have worked a lot with both.
Even though copper-coated aluminum can be soldered, it has a fatal flaw as far as I'm concerned.
Vibrate the wires or cables enough and they become brittle. El Snappo.
Bite the price bullet and go for of the real stuff copper. OFC supposed to mean Oxygen Free copper. Yet another Herb Tarlek buzzword.
The best protected thick cable I have encountered is diesel locomotive cable. Rope stranded double thick tin plated and insulation tough enough.
I get mine through an online accessible surplus seller called SKYCRAFT in Florida. - I would not use any aluminum.
http://www.genuinedealz.com/custom-cables/custom-battery-cable-assembly
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
