I'm looking at a 2000w pure sine wave inverter and the prices are all over the map. Can anybody explain the difference between a $200 unit and a $1000 one? They all seem to have the same features...
Mr Perkuet effect raises his head A battery that has 185 amp Hrs at the 20 hour rate aka 9 amps draw Will not supply 90 amps for two hours And if you manage to use 90 amps for 45 min, you will find the battery is more than 50% discharged, it might be as low as 20% SOC it is the chemical reaction process , producing more amps that fast reduced the SG of the electrolyte
