tealboy's avatar
tealboy
Inverter putting out 98 volts
I'm using a power line cigarette lighter plugin style inverter for inside the cab, running my computer and periodically, for a 32 inch tv for tailgating. I have never checked the voltage until today and was surprised at how low it was.
Is this normal? Is it problematic for my tv, a med size fan or my computer? Worried about damaging the electronics but maybe it is fine. The inverter is a cheap one, maybe $20 or so.
Battery is new reading 12.5 volts and using a basic inexpensive meter to read output.
  • If the tv works all is fine. Just the flat MSW registering low on the pear-to-peak voltmeter.
    Get sine wave or a true RMS meter to read the volts.
  • Considering the cost of a PSW inverter versus a MSW unit. No point is being that cheap in my view.
  • tealboy wrote:
    I added a light load and it went to 110 and up to 118 with a medium load so maybe the no load situation was the problem?
    YES.
    And that also indicates that you do NOT need to throw away your meter. ;)
  • The Modified Sine Wave inverter will not show the proper voltage when using a standard Multi-Meter. I suspect all is well but the meter is wrong.
  • MrWizard wrote:
    Did you read this with devices on, a load
    Or
    Just at the inverter with nothing else connected
    The second method will never give a correct reading
    No load, just connected to the battery. Reading that I need a true rms volt meter instead of my basic one or will never get a good reading
  • Did you read this with devices on, a load
    Or
  • Modified Sine Wave won't necessarily give correct voltage readings.
    How much extra heat are the power bricks producing when using the unit?
Having RV issues? Connect with others who have been in your shoes.24,326 PostsLatest Activity: Oct 22, 2025
