SoundGuy wrote:
Most hair dryers have several settings so although it may take longer ask your wife to only use the lowest setting. I do and my 1000 watt PSW inverter handles the task without any issues at all running by just one 8 yr old G27 battery. :)
Same here, with, I believe, the same 1000W PSW inverter you have. Think it's the heaviest load the inverter/batts see but works like a charm for shorter hair. Longer hair might take awhile though.
But this is far better than turning on the furnace and hovering over the vents, or leaning over the propane range (with a metal plate over the flames).
