mena661 wrote:
otrfun wrote:
I'd like to permanently hardwire the inverter to the battery (with suitable heavy gauge wire), then run some romex or equivalent from the inverter output to an AC receptacle mounted outside (near the frame area), directly underneath the TT's outside power input receptacle.
That sounds like a good plan. Any reason why you want this receptacle outside?
Good question. My TT's main power input receptacle (L5-30P male connector with a flip cover) is mounted on the outside wall. I have to connect my power cable (with L5-30R) to this connector to power my TT. I don't have any outside storage areas to place a receptacle or store power cables. So, I figured the safest place to place the inverter output receptacle was underneath the frame rail, directly below the L5-30P connector, and away from the elements as much as possible.
