Gdetrailer wrote:
2oldman wrote:
Gdetrailer wrote:
Not to mention getting all the family members to remember to turn the inverter OFF when no longer needed, hence the comment of leaving it on 24/7 which WILL happen.
Mine's on all the time. Ain't no thang.
Then you should stop whining about folks with chinese gens parking beside you.
My PV1250 inverter is a rather smart inverter, it KNOWs when a AC load is present and turns on and when the load is turned of it turns off. Saves a lot of battery capacity, lessens that length of gen run time required.
Hard to conserve battery if your inverter is running 24/7, a lot of Ahrs are being burned up by an idle inverter (Up to 2.5A per hr).
2oldman's solar could idle 5 inverters and not be a worry.
We will still complain about the generator running all day just to watch a movie on a nice day. Chinese, Japanese, USA made does not matter.
