Muddydogs wrote:
Another question. I see most inverters are wired close to the battery then regurlar house wire and plugs are used to get the power into the trailer. What problems would I have if I ran about 10 feet of wire from the battery to the inverter so I could just plug stuff into the inverter? I will use the correct size wire, I think the directions called for 4 gauge wire for this length of run.
As long as you use #4 you can mount the inverter where you like. Need an 80 or 100 amp fuse close to the battery. Frame connection would be OK for the negative but wire to the battery is preferred.
