BFL13
Sep 12, 2014Explorer II
The voltage sag when the water pump came on was enough to shut off the inverter (10.5a shut off? ) powering the TV. Use fatter wires from inverter to the DC panel battery lugs so there is less voltage sag (because fat wires have lower resistance than thin wires over the same length)
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
