Coffeemaker can be too much pain with your setup.
With nothing else but TV and lights 160W panel is enough to charge your batts by the evening, on a clear summer day. On a cloudy day - depends how cloudy.
Beside inability of your panel to provide enough amp-hours daily, there is a matter of very high current drawn by those kitchen gadgets. Roy is right - with mere 2 batteries it's better not to exceed 70-80A, so with inverter losses this translates to max 900W device. Your batts won't die instantly if you run 120A, but they won't like it either.
For TV/CD alone, no kitchen gadgets - 300W inverter is enough, and 600W is plenty. Get PSW inverter, some electronics don't work well with MSW type.
Running a generator few times a day to make a coffee - well, I won't comment on that.
