pianotuna's avatar
pianotuna
Nomad III
Aug 16, 2018
inverter review Victron 350 watt pure sine wave
Hi all,
I finally got the Victron 350 watt pure sine wave inverter wired up with a cigarette lighter plug.
It is intended for use with a laptop and heating pad.
Demand with the old 400 watt MSW Motor Master (from Canadian tire) was about 5 amps running the laptop. The MSW got quite warm running just the laptop, and the power supply as well as the laptop got extra warm. The fan would run when booting the computer. When I would add the heating pad the cooling fan ran constantly.
On the Victron demand is down to 3.78 amps, the power supply is much cooler as is the laptop. The case on the Victron doesn't warm up at all. Adding the heating pad did not cause the cooling fan to come on. I should have made this jump a long time ago.
Cost for the Victron was a scant $80 USD.
It is considerably heavier than the MSW unit, and about three times the physical size. I've not looked inside, but I think there may be a nice big transformer in the Victron.
Conclusion:
Highly Recommended!
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
