time2roll
Apr 18, 2017Nomad
Inverter review
Just as MEX and his 5000w inverter review started to get interesting the thread seems to have disappeared. I found the linked review interesting as he seems to strongly dislikes AIMS inverters for ...
theoldwizard1 wrote:Yes the GoPower terminals could be better. With or without this issue, I will always recommend removing the cables from the power source before you play with the inverter terminals.
One of his complaints on the GoPower 3000W was the close spacing of the input terminals (not sure how close the spacing is on other GoPower models). In a different video, I noticed that the 3000W model had shields for both the positive and negative terminals. So if you bolt one cable down, install the shield and then bolt the other cable down and install its shield, there should be no concern about shorting the battery cables. Plus, I certainly hope you have an inline fuse !
