Marv_Hoag's avatar
Marv_Hoag
Inverter setup question
I just installed a Magnum Energy MS2812 PSW Inverter and one of the setup parameters was low battery cut off voltage setting. I set it for 11 volts, after thinking 10.5 might be too low. Don't know if this is a good setting. Settings are scaled in tenths. Would appreciate input as to what others think. I'm running 4 Trojan 6V batteries, rarely without hookups.
  • When you run big loads on the inverter, voltage falls but that kind of low voltage is not the same thing as when the battery is "low"
    Inverters usually have a low voltage alarm that sounds at 11v and then a shut -off at 10.5v.
