wa8yxm
Jul 12, 2017Explorer III
The Sub Panel should have two bus bars. One for Neutral, one for Ground
You connect the ground wires in the sub panel just like you do in the Main
If there is only one bus then you bond all the ground wires with a split bolt
That INCLUDES the one from the inverter.
On the inverter you should have the option to bond neutral to ground... or not
If the inverter has power pass through.. it will bond ground out to ground in when passing through.. The option only applies when inverting.
