MrWizard
Aug 11, 2017Moderator
How did you fry it ?
Too much inverter load?
Too much charging load ?
Or bad voltage ?
The 2000w can use more amps from the battery
Is the existing BATTERY wire big enough to carry the amps
FOR 2000w. Approx 170 amps, when you use full power
Be sure to put a fuse at the BATTERY on the inverter cable that is sized for the existing wire, Not Max inverter power
Other wise you might melt the wire and start a wire
Say when you use the big MW or Keurig coffee maker
Or bad voltage ?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
