road-runner
Aug 19, 2017Explorer III
MrWizard wrote:That's so outrageous that I never considered it a possibility. Good thing somebody can think outside the box! The hit-and-miss troubleshooting hasn't worked, which often means there are two or more problems in the mix. Isolation is IMO the way to go. I like the idea of totally bypassing the freedom, i.e. zero wires connected to it, with the shore cord temporarily hooked to what was the freedom's ac output. In that situation, what AC devices do and don't work?, and does the battery voltage go from 12-something to 14 when the AC power is applied?
If you have 14v with shore power unplugged
There is only one answer
You have another converter in the RV
Probably behind the breaker panel that converter is being powered by the freedom
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
