shastagary
Aug 19, 2017Explorer
instructions say power switch on the inverter should be left in the off position to use the remote panel. when you turn off the inverter from the remote panel ac should pass directly through the inverter. if it does not i would suspect the transfer relay or its control circuit are bad.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
