MrWizard
Aug 19, 2017Moderator
yeah that is strange
according to the manual
output IDLE voltage, no loads turned for the inverter to power
10v to 55v
15vac idle is near perfect
dip switches 7&8 control power sharing
this is the ability of the inverter to reduce battery charging when there is a load using power on the pass thru
normally comes set for 15amps
which is the max setting
10v to 55v
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
