time2roll
Aug 24, 2017Nomad
Is the 2000 removed? I would bench test it with a single battery and a simple 60 watt incandescent lamp as a load. Sometimes there is too much going on and connected to verify proper operation. See how it works with and without incoming 120v power. Then connect the remote and see if it continues to operate as expected.
If all is well only then should it be installed. All three units can be tested the same way.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
