rtate's avatar
rtate
Inverter throwing error codes. Mfg. says ok?
I am installing a Cobra 800 watt inverter in my fifth wheel. I wired it so that one circuit on my shore power panel has the option of either shore power or inverter power. When I tested the circuit on inverter power my outlet tester shows my hot and common wires are reversed. I traced all my wiring and dont see where anything is wrong. When I plug the tester into inverter itself it tells me the hot and the common are reversed and there is no ground connection.
I spoke with the tecs at Cobra and they say that is just the way it is configured and that a circuit tester will throw error codes but not to worry about it.
Does this make sense to any of you experts out there?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
