patchedup's avatar
patchedup
Inverter too small?
I have a 1000w cobra inverter i bought to power a small 5 cubic foot freezer that pulls 4 amps when running. The battery i use for the inverter is 105 amp marine deep cycle group 29.The inverter is connected to the battery with shortened battery jumper cables, at about 3 feet long, from the battery to the inverter. After about 5 hours the alarm on the inverter sounds and indicates low input voltage of less than 11 volts. The battery at startup was charged up showing 13 volts on my meter. Is the inverter too small or is the battery to small? I thought i could run the freezer with this setup for at least 18 hours. With this info i can forget running my cpap off this setup for overnight. Thanks!!!!
  • Almot's avatar
    Almot
    Explorer III
    patchedup wrote:
    Thanks. Sounds like battery is not enough or not charged enough.
    There is no "or" - the battery is not enough, period.
    Simple math. 12V draw is 10 times 120V draw, plus inverter losses. You draw 44A from battery. Moreover, at such a high current the battery capacity is less than nominal - too long to explain why. So in 1 hour it is down to 50% even it was fully charged. If fridge cycle is 25% on/75% off, 1 hour of running = 4 hours time.
  • Hi,
    None of the Cobra inverters are PSW. Some are rated to run microwave ovens.
  • Almot's avatar
    Almot
    Explorer III
    If it is not PSW, this not good for a motor.
    Also, 44A @12V (or 4A @120V) is too high, even for a freezer.
    I suggest you get a 12V model, they run on less than 8A @12V. Like this Sundanzer DCF165 (DCR 165 is a fridge).
    Or German Steca PF166 - this one can work either in fridge or freezer mode, and costs about the same.
    Either model has 5.7 cu.ft volume, and draws 50AH per 24 hours at 90F ambient temperature with "average household use", according to their data sheets. This is roughly 25 Ah overnight, so if your goal is live through the night without running a generator, this is what you need.
    I didn't look into latest 120V freezers, they are getting better and better these days, though you can't beat 12V models in terms of energy efficiency.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
