I choose the 1000 Samlex from a local dealer. I mounted the remote switch inside basement right beside battery cut off switch. Within inches of the power bar where Ipluged in the converter.
Stepped into trailer to test. Tv on disc player on.
Turned on ceiling blade fan. Then stepped out to check the display on remote switch. I expected that since the fan was running I’d expected to see the output indicator on the display would be higher. So I’m happy.
However when I stepped back into trailer the moment I shut off the fan the GFI switch in the bath snapped. ??
