big_buford's avatar
big_buford
Inverter voltage
Have a go power sine 2000w inverter. There are 2 dip switches to select voltage output. Factory setting is 115v. When set at 115v I see 111v at the inverter, 110v plugs on rig and about 108v on icemaker line while running. Is 108v too low? I set inverter to 120v setting, read 121v at inverter. Will test ice maker this next weekend at 120v setting while out camping, but given the above voltages which would you run? Will the 120v setting use more AH's? Thanks
  • I would probably set it at 120 especially after seeing your readings. That is the standard voltage these days. Maybe draw about 3-4% more.
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
