llr
Jan 19, 2016Explorer
If the converter is left on it will shorten the battery life, not add power.
Everything has loses so even if the inverter and converter are each 90% efficient which is probably high you will only but 8 amp into the battery for every 10 amps taken out
if the converter has its own breaker turn it off, otherwise find another method
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
