n7bsn
Sep 30, 2014Explorer
This is the one I used. It switches as soon as the Inverter is powered up.
This can be important as you should NOT bond the Ground and Neutral together. That is never done at sub-panels or connections below the main panel (ie the first panel after the power arrives from the transformer)
I lead the power from the trailer breaker panel to the transfer switch, then back to the panel to connect to the load.
