wolfe10
Jul 01, 2016Explorer
What wire gauge was recommended from batteries to inverter in the inverter installation manual for your length wire run?
1 Gauge is very likely too small.
And pretty easy to check:
Check voltage drop across the wires-- when someone starts the refrigerator, with a digital voltmeter check voltage between house battery positive and negative lugs.
Check again at the inverter positive and negative lugs. Any delta between the two means resistance in the cabling. 2% drop is commonly recommended for primary circuits.
While large gauge wire is not inexpensive, it is sure the least expensive "fix".
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
