djousma
Jul 02, 2016Explorer
dougrainer wrote:
Is it possible that the Freezer Door was NOT sealed tight. It may have slightly opened from driving? 11 degree jump in 2 hours from zero is a big jump when you consider the refer was NOT having its doors opened. IF your stationary test on Inverter shows no rise in temp in that 2 hours, you need to consider the doors not being latched correctly. Doug
I guess anything is possible, and maybe even likely, since the refridge side stayed at the set temp. I'll pay more attention to that. There are heavy elastics that go across the doors for travel, since like a typical new home unit, there are no latches.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
