Hi,
My magnum 3000 watt will charge at 125 amps from a 15 amp supply. The yamaha generator will do 16 amps continuous.
smooth1 wrote:
My questions are on the 100amp chargers on these inverters. Will the Yamaha 2000 be able to power those 100amp chargers if I need to charge the batteries when I winter camp. Also, is the PD9245 going to put enough amps into the 3-4 batteries or should I just take it out and use the inverter/charger only. If the 100amp charger won't work on the Yamaha 2000, then can I just leave the 9245 and switch to that to charge the batteries off the genny. I have heard a PD9280 won't run on a yamaha2000. Will the 100amp charger work on a 15amp 120v outlet from my house? Kinda confused on these larger chargers.
