BFL13
Jan 23, 2015Explorer II
ewarnerusa wrote:
There was no load on it when it faulted. I do believe that others mentioned the bonded neutral something something that might trip up an inverter when I asked about on these forums. All other inverters I have used work this way, just that Samlex one didn't. And the Samlex one worked for directly powering things, just not through the shore power cable route. My solution was to get a different inverter since I decided I need PSW.
My MSW Vector 2000w and 1000w PSW Xantrex inverters both say not to run an AC dist with them but have no trouble running an RV "whole house"
Obviously it doesn't matter now, but IMO there must have been some "issue" other than that at the time. If there was no load then it must have been a connection issue that you didn't catch? Doesn't matter now anyway.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
