MEXICOWANDERER
Jan 23, 2015Explorer
Answering the question regarding a "switch"
A double-pole On-On switch allows switching both the leg and neutral to each device. You should look for a switch rated 25 amperes. An on-on switch toggle has two positions. Up or down. No middle position (which in other switches would be the "off" position.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
