wolfe10
Jan 23, 2015Explorer
E&J push'n wind wrote:smkettner wrote:
or wire the inverter to provide power after the converter so that you have no issues.
Can you expound on this please?
I suspect (please confirm) that he is suggesting that inverter output be routed to a sub panel with only those circuits that you want to have powered by the inverter. This ASSUMES that the inverter has a "pass-through" feature so that those circuits powered from the sub-panel are also powered directly from shore power or generator if either is present. This is actually the best way to wire an inverter and is the way many higher-end coaches are wired from the factory.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
