E_J_push_n_wind
Jan 24, 2015Explorer
smkettner wrote:
http://www.donrowe.com/KISAE-TS20A-Automatic-Transfer-Switch-p/ts20a.htm
Thank you for the link!
smkettner wrote:
For low wattage you can probably tap into the main 12v battery connection and call it good. Then use a small transfer switch to send power down the branch circuit that powers the convenience plugs. If you have two circuits with outlets you need two transfer switches.
I take it that this will be indicated by two seperate circuit breakers? I hope they are labeled! Believe it or not, I haven't looked at that breaker panel in some time and then it was only once. I'm not really sure what I will find when I see it. So far the only thing I've done "electrical" to my TT is add a hard wire Progressive Industries 30 amp surge guard with a wired remote. That was easy, other than that I've had no need to fiddle with it or anything. All has work as expected so far.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
